Root V6 supercharger
that one dude
I used to use this with the og EVO and worked fine I am stock rooted with s-off and now when I try to run it some service.jar thing comes up I guess its to do with the Rom being odexed can somebody give me some info on this please...
Yeah, has nothing to do with odexed.
Here's the thing - the values that V6 tweaked before are still there but in some cases their meanings have changed for ICS and in other cases, what really needs to change is done within that binary file, /system/framework/services.jar, so zepplinrox provided for that as well.
For full effect, some of the custom LTEvo roms have it baked in.
Ok but what can I do to fix it? It routed me to zepplinrox page to upload that jar but wouldnt go on from there. I'm sure flashing a new Rom would do the trick but I wanted to stay with the stock Rom for a min before doing so...
Ah - I understand, I've been through this.
Can you lay the link on me for which thread you're following to get you there?
There are a lot of them out there, and some may not be maintained properly.
Meanwhile, I'll look for the thread I used that worked.
