It's easy. Download busybox installer and script manager from the market. Download on your phone v7 or v8 script from the xda site directly to your SD card. Copy it and pate it to the home section of your card. That's known as putting th there in alphabetical ordere file on the root of your card. Now it's not hidden from the script manager. Now push your finger on busybox installer icon. Allow root, select busybox 1.18.2 and push the install icon. If it fails do it again. Once it installs go to script manager. Push onit. Let it open. Push your left hard key button. On thescript manager you'll see more. Press that. Then Advanced options. Then check browse as root. Go back to script manager first page. All of your root files are in alphabetical order. Touch the v6 file and when another page comes up check ruinas root. Then press run. The first number it asks you to enter is 1 2 or 3. It doesn't matter. The second time it asks you to enter a number is the script. I use 2. 4,5, IE6 are good choices to try. After you enter these numbers you hit the return arrow in the lower right and you'll se kbe stuff happen. Follow the directions. Good luck
READ THE DIRECTIONS AND LOOK AT THE PICTURES ON THE COMPUTER BEFORE AND WHILE DOING IT.
