Vanilla Lockscreen wallpaper help
WiiZYBaBY
I am running Fresh 2.3.3 and I have the Vanilla lockscreen enabled. I have tried a lot of patches and metamorphs all locking my phone and sending into force closes and boot loops. My question is is it possible to change the vanilla wallpaper on Fresh? Is there a way to find the wallpaper used and change it? If not I'll live with it. It looks much better then sense with fresh :-) Thanks
I ran into a similar problem with my first go'round with Fresh 2.3.3. Turns out it just takes around 10 minutes or so to apply the lockscreen update. I just reflashed the ROM today and was able to apply the lockscreen update through Fresh Updater. The phone appeared to be in a boot loop for quite some time but eventually caught up.
As with just about every other package you try to flash, remember to run a nandroid before you do. Rebuilding your layouts from scratch gets annoying after the 3rd or so time.
