I had a new nc running 1.3. Used the guide here, option #3:
http://androidforums.com/nookcolor-all-things-root/352736-how-install-cm7-your-nook-color.html
(thanks colchiro for all the work you do on this forum)
Used the files in that guide 7.1 encore and gapps.
I installed CM7.1 first rebooted then installed gapps and rebooted.
Here's the errors I keep getting.
When I start up and continually thereafter I get "Sorry The application Market (process com.android.vending) has stopped unexpectedly. Please try again."
I also get "Sorry the process android.process.media has stopped unexpectedly. Please try again"
I also have "problem loading widget" at the top of my device homepage.
I obviously can't get in to market, just get error #1 if I try.
I first installed from a kingston card. I read that I should use sandisk. Switched to sandisk and ran through the entire process of option #3 from the instructions and the device looks and acts exactly the same as before.
Couple of questions. Is there a way to start completely fresh to run through the install process again clean? It doesn't look like I am doing that, since all my changes I made for the first install are they when I run through the install on clockwork again.
Obviously I need help fixing the market first and foremost, so if anyone can point me in the right direction I would greatly appreciate it.
Thanks.
Thanks.
