Since factory resetting (to fix the wifi), I have had the following niggly problems:
(i) "System UIDs inconsistent" message on start up. I hitt the "feeling lucky" button and the pad seems to work OK
(ii) weather widget won't allow me to change location, so it is stuck on Shaghai. Fails with:
"Sorry! The application WeatherForecast (process com.android.weatherforecast) has stopped unexpectedly. Please try again"
(iii) can't change wallpaper
(iv) the Weather Channel app has stopped working - allows me to choose a UK location, but not getting any forecast info
Any ideas how to remedy some or all of these ? Reflashing ? Rooting ?? I haven;t done anything else to my Flytouch except the factory reset
Thanks,
Keith.
Thanks,
Keith.
