Uh oh haua yea i wanna avoid that. (although I already had some problems as you can see from my posts in the other thread
So first relock, flash old ruu (through adb on the commands? The way the permanent recovery was flashed?) THEN flash New ruu? And this will take care of hboot as well?
you can relock and run the 2.01.605.11 RUU as a .exe file, or as a PH98IMG. or you could follow the directions to flash the 2.01.605.11 "mini-ruu" then relock after. however youre comfortable doing it is fine,i think you just want to be on stock software when you relock and run the leaked RUU.
you can run the leak by renaming PH98IMG and putting on your sd card,or by putting it into your adb/fastboot file and flashing it in fastboot just like the mini-ruu:
fastboot flash zip rezound_ics_androidpolice_3.11.605.22.zip if you dont rename it.
either way,be forwarned that after the hboot pre-update,the phone will boot back to bootloader,possibly powering off for a few seconds in the process. dont panic,just give it a few seconds for bootloader to come back up.
if youre running the ruu in fastboot,be aware that you will get a 'hboot pre update fail! please flush again immediately' error,wich is normal. wait for the RUU screen to come back on,then run
fastboot flash zip rezound_ics_androidpolice_3.11.605.22.zip again immediately. if youre on stock software,it should finish the second time.
for S&Gs,heres how it went for me:
-booted to fastboot
-launched recovery
-made a backup of business sense 2.3
-booted back to fastboot
-relocked
-immediately got the
security warning
-erased cache,put it in ruu mode
-ran zip with above command
-hboot preupdate failed. powered off.
- i didnt wait for RUU mode,went ahead and entered the command again
-phone came on in fastboot,not ruu mode. showed status bars while cmd window was "sending zip,parsing,etc"
-error in cmd window "update fail! remote not allowed"
and then
tampered popped up. powered off. this time i waited for bootloader to come back up before entering any commands.
-erased cache again(i think),put in ruu mode
-flashed zip a third time with the above command
-picked up where it had left off,and finished this time. *sigh of releaf*
-finished,booted,gave it a few minutes to settle. enable usb debug,boot back to bootloader.
security warning and
tampered were gone hooray!
-re-unlocked with original unlock token
-reboot,let settle,enable usb debug. boot to bootloader
-back to
unlocked,but
tampered was back.
dammit!
-launched recovery,flashed superuser. rebooted. let settle
-signed into google,download titanium,restore rest of apps. good to go
so my bootloader screens(hboot and fastboot) still say
tampered,but it doesnt seem to affect anything. hope that helps.
