Vehicle charging mount?
sorka
The S3 was almost a non starter. It turns out the Infuse vehicle charging mount just happens to fit. Not as smoothly or one handedly as the Droid X and it's factory mount, but it was decent and over the last year it hasn't ruined or worn the finish of the S3 after hundreds of mounts and dismounts.
Otherwise, I would have had to send the S3 back and go with another Motorola.
So now it's the beginning again. I have searched and see no vehicle charging mounts that will charge the S4. Since the sizes are very similar, it's possible the Infuse dock will still work.
Has anyone tried it by any chance?
Mounts like the iBolt where you have to plug in a separate cable are a non starter.
I don't know this mount but if it fits the S3 properly then no, it won't fit.
The S3 and the S4 are a similar size and shape but not similar enough for a mount that fits either properly to fit the other.
Brodit do a mount that doesn't need plugging in separately. I don't have one for the S4 but I have had a mount of theirs in the past and it was well made and fitted perfectly.
