Root Velocity 1.x Themes
j2cool2012
I took it upon myself to create a thread with an updated list of the themes available for Velocity 1.1, along with screenshots of the themes. That way, people know what they're getting!
Download this custom bootanimation HERE
FLASH STOCK THEME BEFORE RETHEMING!!
_______________________________________
STOCK 1.2 By J2cool, Savoxis, and Trident
Image Gallery HERE
STOCK By Trident [Repackaged by Lefty] (Script # 9)
Stock theme for offline reverting here
Meizu M9 By GRZLA (Script #5)
SeMIUI By j2cool (script #7)
Third Party Apps:
Fancy Widget Pro OR MIUI Clock Widget
PseudoSense By j2cool (Script # 6)
Third PArty Apps:
Old Fancy Widget
HeLauncher
Elegant Gingerbread (EGB) By j2cool (Script #2)
ThunderBolt By GRZLA (Script #8)
Third PArty Apps:
Old Fancy Widget
HeLauncher
________________________________________
HoMeSiCk By MikeW (Script #4)
VeloCyan By remicks and J2cool (script #12)
VelocicombFire By k.c.cole (script #11)
Updates as new themes become available
Were you able to interchange them? I've had to reflash velocity everytime. It doesn't seem to drop the theme when i change them.
I knew this would come up...
See, the thing is: with the new theming engine, you only theme what you want to change. So, if a themer does not change EVERYTHING, whatever theme that was on last that was not touched will stay there. I believe that is what you were referring to?
This is what i mean. I set the theme as Meizu. Okay, it themes it exactly as expected. Now i want to go back to stock, so I use the Stock theme (all from velocity toolkit and emulator), but when the reboot is over, the Meizu notification and icons are still in place.
I have also been experimenting with Metamorph, but every change I make becomes very unstable. And I can't get the Meizu battery icon to go away at all, when trying to flash the honeycomb battery icon.
When i flashed the PseudoSense the dock bar is not showing as it should show above, and also when i was reading thru the script as i was downloading, it said youtube not found. and so im guessing the theme couldnt be applied. :/
Hmm my Pseudosense looks nothing like that. At least everything runs. Should I redownload Pseudosense to try and get it to look correct, and if I do, should I go back to the default first? This is very frustrating, I like the Pseudosense theme.
I'm also missing several icons.
My problem is the same as Kris' above me.
especially the dock bar D:
i flashed the thunderbolt theme. my god this is amazing i can trick my friends saying i changed my processor to the thunderbolt ^_^
You guys need to hit up tiny.url/j2cool because when you 1st flash it says in the info to go to that link to be able to get the launcher so please read 1st before anything
uhh, i did go on the tinyurl.com/j2awesome and the only theme is velocity 1.0
That's all fixed now. always go back to stock before retheming. The stock.zip works now
First will type fresh still work to change fonts.
Second. Does the ginger blue theme still exists. Will velocity 1.0 themes work.
I haven't found this problem covered yet. Sorry if I missed it. When I go back to stock theme the market force closes every time and I've had to reflash 1.1 three times. Any fix for this?
LOL @ everyone wanting the awesome dockbar. it's a LAUNCHER. called HeLauncher. Get it from the Android Market HERE, and select it. Click Menu, click "customize" and select the sense theme. And as for Market FC's...idk. This has not happened to me on any of the themes.
