Verify OTA update installed or not?
nbm400
Member
Anyhow know how to verify if the system update has been installed on my phone or not? I accepted the download, but did not run the install. I then ran a factory reset to try to clean things up. But then worried that it auto-installed when the phone reset. Any ideas how to check what I got?
Thanks.
Man this phone is sweet... gotta say it's overloaded loaded with sprint bloatware tho, sheeesh.
Thanks.
Go check your menu-settings-about phone- check your software version. If it ends in 1, then you still have the original software the phone came with, if it ends in 6, then you installed the OTA update.
As far as the sprint apps, the only way to remove them is to be rooted.
