Yep it'sme again! I just ried to view a Facebook vid but can't cause I ain't got no Adobe flash installed...BUT I have the .zip on my sdcard. When I have tried to install it I simply can't
How would you suggest I approach this most serious and important task Sir?![]()
...although, since I'm running 4.1.1 am I going to have issues? Just read the pre-installation cautions and basically anything beyond 4.0 is if-y...
What to do what to do...![]()
Well I guess that my very first vid I try to watch AFTER installing Adobe fp says that Adobe Flash is required to view this...but it IS installed! Is this what is meant by it works most of the time but not always?
:smokingsomb:
What browser are you using? Try different ones. Boat browser generally works for me, but sometimes I have to go to Dolphin, sometimes the default browser works. If you try to watch flash videos in chrome it will always give you that message regardless of what version of Android you are on. Your best bet is to download boat Browser from the market, open the settings, set flash to "always on" and load the page there.
Just curious, since you have been using Boat for a while, can the full blown website be accessed in Boat? I personally do not care for the 'mobile' version of a website! I have been looking in settings and such but cannot seem to locate it -IF it's even there! Thanks![]()
Sure its in the settings. It's called desktop mode. Their is also a function called night that will invert your browser for massive battery savings.
Not sure if an upgrade version has removed that preference but I have been all over the 'settings' and cannot seem to find it!
Any chance of a screen shot?
Menu button > settings > page content settings > set user agent =desktop
The Adobe setting is right below it set to = always on
Reboot then good to go.
Aha! Got it thanks![]()
For me to view flash on my Verizon GS3 I had to install the flash apk and also download the Boat browser app. Then in the settings, allow flash. And boom. flash. doesn't work on my stock browser nor chrome.
I don't get what the big deal is with certain vendors wanting to not support Flash. There are untold numbers of websites that *require* Flash just to view their content. One such site is the National Geographic Magazine Archives, which I like to read sometimes. If you are using a browser that doesn't fully support Flash you can't even operate that site's issue index interface. I really doubt that sites with a lot of time and money invested in a Flash user interface are going to just change everything to some other kind of interface because some individuals decree Flash to be "evil".
I am trying out Boat Browser in my Jelly Bean ROM tablet, to access this site. One thing I don't like is that Boat Browser is not allowing me to use the left/right cursor movement keys (for editing and typo correction) while typing this using Super Keyboard. Oddly, the up/dn cursor keys work.
Two words. Touchpal Keyboard. You can thank me later.
It is very nice, and I did try it on my tablet. But I chose Super Keyboard on my tablet specifically to GET the cursor movement keys, because the tablet has too much ground to cover to use a Swype style entry when in landscape, which is how I use it all the time.
They work great on any kind of document or website - EXCEPT when using Boat Browser.
I use the one that gives me the least problems, based on what website I am going to visit and how it handled that site when I tried it.
