Thanks
What about "since unplugged"?
Same combo I`m running on 2 devices. Dam. Maybe you just have a cycled/memory depleted battery . . . ???
... can you 'splain it?
Is this normal cpu usage for being idle . . . ?
No Dk . . . thats my screenshot! A cycled battery as I call it is a battery that can`t deep cycle (discharge slowly over time) anymore . . . meaning that when fully charged, or what you THINK is fully charged, Has reduced discharge time. Example: A good battery = fully charged to 100% will yeild results like I`m getting now . . . still @ 94% after almost 9 hours of standby.A cycled battery = charged fully - in the same phone - will discharge much faster as it`s capacity, or ability to hold charge is reduced. Just speculation here . . . you might try another battery before you spend lotsa time diagnosing erronious consumption in your device that may not even be there . . .
I`m sure I spelled that fancy word wrong . . . !
I`ve been reading your other thread . . . With the same rom/kernel combination on the same device, you have drastic battery drain, wheras I have phenominal battery life. The only difference is the modem & rpm. Do you have the original/previous versions you were using ? If so I would go back to them & see what happens . . .
Would this help? It appears to have the previous modem before the VRBLK3.
[MODEMS] <VRLK3> Verizon SGS3 (SCH-I535) [ODIN or RECOVERY-flashable] - Verizon Galaxy S III Development - RootzWiki
I don`t think it`s the rom. I`m running 5.6 & the battery life is the best I`ve had yet. The only other changes you have made were the modem & rpm. I would go back to what you had before & see what happens . . .
We got 2 threads about the same issue going on here I think eh?
Perhaps I will do some merging? eh?
Well done as usual o wise one . . .
