On the Inc, several kernels began including a "volume boost" a while back. I'd venture to say it will be included fairly soon on some kernel work with the GN. Nothing that I have seen yet.
Post above is a solution try volume+
Hope so, because this low volume stuff is making me miss calls. With this OtterBox it doesn't help either, I can't feel me phone vibrate anymore...so kind of a double whammy.
Does this Volume + help increase the ringer volume of the phone or just the speaker or headset volume during calls?
it can do all 3, but the main advantage is the external speaker boost. this is what is used for your ringtones/notifications, so it is the setting you are really going to want to play with. i am using the free version from the market at +4, and it has helped immensely although i am still thinking about paying for the full version that goes to +10.
axiom 2.2 makes the speaker much louder.
Thanks for the nfo!
Was just looking at installing this. How do you like it?
On the stock locked 4.0.2, you can't go over +8 on the paid version of Volume+. Anything over that and it goes quiet.
Custom roms will be required to get the +8 - +16
