My only experience with rooting was with a Droid X over a year ago, and it was basically a 1-click method. After reading the root guide above, things seem a bit different on the Gnex, so I've come to confirm a few things before I get started.
First of all, I have already unlocked the Bootloader (did this on day one so I wouldn't have to erase everything again). So I have the Samsung drivers installed, have adb and fastboot ready to go, and know how to enter Recovery by holding both volume keys and the power key.
However, before rooting I'd like to clarify a few things:
1) When I root, I won't lose all of my apps, homescreens, or app data, right?
2) I'm not sure whether to use the Clockwork or Superboot method as outlined in the root guide? The Superboot method seems easier since I am already Bootloader unlocked, but I wanted advice first?
3) In the Clockwork method, it says I can either "softboot" the custom recovery or "flash" it. I don't understand the difference? By custom recovery, we mean the screen that appears when you do the power button + volume button restart, right?
If I just softboot it, that means it only appears for that instance while I am finishing the root? And if I flash it, it means I now will have permanent custom recovery, right? If I do the former, I'll be able to run root apps, but will not be able to do nandroid backups or flash roms, right? If I do the latter, I'll be able to do it all but will not be able to get OTA updates without restoring the stock recovery? Please correct me if I'm not understanding this correctly.
4) My main reason for rooting at this point is just to do nandroid backups and use Titanium Backup to backup/restore app data. At this time, I am not interested in roms or anything else. Given that, what is my best method for rooting while still retaining the ability to do OTA updates?
Thanks!
Thanks!
