[Verizon] Can I get better lock screen customization than Widget Locker?
bluroot
I have to give this app credit (Widget Locker) because at least it does what it claims. I also tried Magic Locker, which could superimpose many completely different lock screens, but they were not true lock screens because the back button could circumvent this app.
So the best I've seen available for now is Widget Locker, which really doesn't seem to offer that much at all. I may wish to add more than just three custom buttons to my lock screen. More importantly, I would really like to do away with Google's very ugly standard lock screen altogether! I hate having to swipe to the side (it's impossible with one hand), and I really, really don't want to have Google Search waiting to infuriate me every time I thumb vertically, which I'm used to doing on my old phone. I simply cannot think of a more pointless and obnoxious app than this in a time when every web browser in current use has a link to the search engine of your choice from the URL line. Widget Locker does not allow me to tweak the standard Google "features", and I wish to change my swipe orientation for unlocking the screen as well, thank you!
I recall knowing that this was possible when some of my apps (such as music players and at least one home screen) offered their own swipe screens, which bore no aesthetic or mechanical resemblence to the manufacturer default. They actually worked, but the last time I used one I was running Gingerbread (I'm on Jelly Bean now). Did evil Google go and make this impossible?
I am posting this here because I suspect that what I want to do, if it can be done at all, may require root access.
Running custom ROM JBSourcery and they have a ton of mods for your phone. One under lockscreen is to simply long press the lock button and it unlocks, no swiping. You can also change your targets to open any of your apps.
Thanks, that sounds great. But is there no way of getting such modifications without flashing a whole different rom? I just recovered from a mess where the Jelly Belly rom left me without the Google framework, and I wasn't sure if any of the gapps files would work with my system.
If you were running Android 4.1.1 before you romed your phone, and the Gapps file for jelly bean, your phone and carrier is "not recommended for android 4.1.1", does that still matter now that you are running a different system? Does the rom completely supercede Android, and if it does, then would I need to find a gapps file specifically for the rom?
You don't need anything specific for that rom, but you need something for that specific OS base. For example, let's saying you're running a 4.1.x rom. You'll need gapps that are 4.1.x compatible. Same with 4.2.x roms. You'll need gapps that are 4.2.x compatible and nothing else.
With that being said, there's no gapps that are linked to any specific rom, just the base. Hope that made sense =)
I am guessing that since you posted in the Verizon rooted section you are already rooted and on Verizon most importantly running a Galaxy Nexus.
Goto the ROM Sourcery thread in this forum, click on the download section it will take you to a page to download the ROM and Gapps. Obviously do the standard backups of your devise first.
If you are not rooted, I had a great experience using the galaxy nexus toolkit v10.1. Though a newer version may now be available.
I used ClockworkMod Recovery to get rooted, which was surprisingly still on my phone after going "back to stock". But now I just started getting the OTA upgrade nag every two minutes!:banghead:
Oh, goody, looks like Verizon's finally ready to give me 4.2. But will I need to re-lock my phone (and can this be done without unrooting) in order for the OTA to install? Are the benefits of roming (ROM) the upgrade really worth the hassle of another data wipe, followed by more hours cursing my backup software?
personally, i find the roms out for the Gnex to be far superior to the ota's. The developers take the "stock" build and add so many goodies for us that it truly lets one make their phone as they wish.
have heard installing the update will break your root access, if you so desire to let it install. so that leads me to believe you dont have to lock your bootloader to take the OTA
