[Verizon] Can I get rid of Playstore links?
Hello everyone,
So when I flash a new ROM, I have the fun of reinstalling my apps from the play store some of the time. I use titanium backup for some stuff and fill in as needed. There are some apps that I tried and don't want anymore, but when I go to my apps they are still there (this is a good and bad thing).
Is there a way to break this link to specific apps that I don't want showing up anymore (like before I rooted and flashed custom roms, I used some of the Go screen lockers, nice at the time, but now I don't want them to show up anymore).
There must be a way to do this.
Thanks
-S
first uninstall the app, then open titanium backup
locate your app, select it and hit delete
that removes it from the titanium backup list.
hope this helps
hope this helps
Thanks for the help. There is a detach from the market and I can delete the back ups but no delete of the application. Do you mean detach from the market?
Well I tried this and I still get applications that are not installed, but show up under My apps under all. I am tired of looking at banking apps that I tried and that didn't work for me.
Thanks again.
S
No, I even called Google about this to complain. There's apps I downloaded and used for less than a minute and they show up in the play store.
