sdrawkcab25
Extreme Android User
Has anyone loaded up or tried any of the CM9 nightlies?
Seems there is a bug when using the search feature in any google app, or searching from the address bar in the browser. Even the static search bar at the top of the home screen immediately closes(not force close). All google apps work fine otherwise.
Just wondering if anyone else is having the same problem. Other than that, it seems to be bug free
CyanogenMod Downloads
Edit: nevermind, flashing another nightly overtop fixed it. Bug free
