You can assign any pic you want to the contacts. Problem would be you would have to change each contact individually. Open the contact you want to change, then choose Edit and tap the contacts pic and choose what you want to use.
I would surmise to change all the contact pix to a different default image, you'd have to get into the OS, or rom and find where that image is, then change it.
That's above my paygrade![]()
Yes, I'm actually digging in the OS to find and swap that default image right now.
Sweet! Please share if you find it, because I agree that the default image is kinda lame and would be cool to change it
I'll buy you a cookie if you succeed (nice incentive eh? lol )
^^^ My Hero!
Hey, if you can make it so every unknown caller looks the same that would be awesome. Make them this guy.
NSFW
wow!! Kudos to you!!Ok, I've FINALLY figured out the SOLUTION to this problem!
Step 0: MAKE A NANDROID BACKUP OF YOUR PHONE!
Step 1: Download the free 7-zip utility if you don't already have it.
Step 2: Use 7-zip to open Contacts.apk in \system\app
Step 3: Within Contacts.apk, locate and replace desired image files in the following folders: \res\drawable-xhdpi, \res\drawable-sw359dp-xhdpi and \res\drawable-sw359dp-land-xhdpi. (replacing image files in all of these locations may not be required based on phone model)
Step 4: Use 7-zip to open Phone.apk in \system\app
Step 5: Within Phone.apk, locate and replace desired image files in the following folders: \res\drawable, \res\drawable-sw359dp-land-xhdpi and \res\drawable-sw359dp-xhdpi (replacing images in all of these locations may not be required based on phone model)
Step 6: Reboot
Step 7: ENJOY!!!
** Name replacement files the same EXACT name as the original file it is replacing.
*** Try to make replacement files the same size and resolution as the original image files.
**** I don't think it will matter much but I'm using an AT&T Galaxy S3.
, I know what 7-zip is but how do you use that with the apk that is on the phone???? Use the computer somehow? Sorry, yes, I am corn-fused
Since I'm a dumass when it comes to this kind of thing, I know what 7-zip is but how do you use that with the apk that is on the phone???? Use the computer somehow? Sorry, yes, I am corn-fused
Yes, I used the computer to do everything. You will have to get SeContacts.apk and SecPhone.apk to your computer, follow the steps outlined above and then copy those two files back to your phone. Remember to set permissions. I'll update the previous post with more detailed instructions.
