It's not a true rocker switch. If you depress one end, you can still independently depress the other.The volume control is a rocker, depressed either one way or the other. It is not possible to hold VolUp and VolDown at the same time.
While the plastic outer button is one solid piece, it doesn't actually raise at the opposite end of a press. It's also designed to depress both at once, if pressure is placed in the center or on both points, equally (such as when using your entire thumb).
Upvote
0
