Verizon Galaxy Nexus will fit....?
yankies90
will Verizon version of Gnex fit with international version of Gnex case?
I am currently using extended battery and its slightly thicker cover.
Anyone can confirm?
Maybe, maybe not. The LTE version is slightly thicker then the GSM version. If you are using the extended battery too, it may not fit. If it does, it'll be a very tight fit.
My concern as well, with a different accessory.
I pre-ordered the horizontal media dock for Nexus, hoping that my Nexus - with extended battery - will fit in it. Should be released for shipment in a few days; the extended battery only adds 0.5mm thickness to the phone, so my guess is that it will be snug but it will fit. I guess time will tell.
In your case, perhaps the only way to really know is to try it. Order your case from a retailer with a good return policy and let us all know whether it fits or not :)
