While a one click would be nice, it is a bit early to expect that on a phone just released. Still, the steps to root are actually rather simple if you have them layed out. It took me about 8 minutes to do. Here are all the steps I followed.
Here is my collection of others work regarding root.
Step 1 - Preparation
Download and Install Samsung Official USB Drivers - Link (
http://downloadcenter.samsung.com/c...ng_USB_Driver_for_Mobile_Phones_v1.5.14.0.exe)
Download and extract ODIN v3.07 - Link (
http://samsung-updates.com/Odin307.zip)
Download the VRUAMD2 Prerelease Kernel - Link (
http://open1your1eyes0.cnlson.com/SCH-I545_MD2_423399_Kernel.tar.md5)
Download the VRUAMDK Stock Kernel - Link (
http://open1your1eyes0.cnlson.com/SCH-I545_MDK_562219_Kernel.tar.md5)
Download and extract the Motochopper Root Exploit Tool - Link (
http://open1your1eyes0.cnlson.com/motochopper-supersu.zip)
Step 2 - Flashing VRUAMD2 Prerelease Kernel to remove Root block
Boot phone into ODIN mode (power down, hold in down volume, home & power)
Flash the VRUAMD2 Prerelease Kernel using ODIN v3.07 ***in PDA section only*** (See here for guide on flashing)
Boot back to Android and verifying everything is still working and kernel has flashed successfully
Step 3 - Rooting Your Device
Verify in Security on your device that you have "Unknown sources" checked
Verify in Developer options setting on your device that you have "USB debugging" checked
Verify in Developer options setting on your device that you have "Verify apps via USB" unchecked
Connect your phone to your computer and open "Run.bat" file from the location you have extracted motochopper to
If successful, after your phone reboots, open SuperSU app and let the binary update itself to the latest ***IMPORTANT*** - You will loose root on the next step if you do not do this.
Once complete, just open a root application and verify that is able to access root properly
Step 4 - Restoring VRUAMDK Stock Kernel
Flash the VRUAMDK Stock Kernel using ODIN v3.07 ***in PDA section only*** (See here for guide on flashing)
After your phone boots back to Android, you should now be fully rooted and on the fully original stock firmware as the device came
After rooting I wanted to also install ClockworkMod. That took a bit of digging, here is how I did it.
download Loki files from here:
Rwilco12's Android Repository - Downloads
Unzip files, then push to phone with ADB:
adb push loki_flash /data/local/tmp
adb push recovery.lok /data/local/tmp
Install Android Terminal Emulator from play store on phone
In terminal emulator:
su
Allow SuperSU Access
cd /data/local/tmp
chmod 755 *
./lok_flash recovery recovery.lok
reboot recovery
