[Verizon] help deciding roms
Hardstyle
I haven't been on here for a while so idk what ROMS r good and what not. so I'm looking for a ROM that will help my battery life the most. i don't need to have the phoebe faster since its fine at 1.2ghz
A mod suggested to another person
Solid green was the name I think of the mod
The rom anyways liquid smooth for great battery life
I think you are thinking of SolidOrange he is a guide ;) and yes Liquid is a great rom IMO as well
Would changing a Kernal help battery life too?
Kernels do affect battery. If you are running stock you may have a hard time finding a kernel that will work for you. I would suggest trying out some roms. Liquid is a good rom. I also like Codename Android. I hear great things about all the roms out there however and since they are rather easy to change if you flash one and it doesn't tickle your fancy you can easily flash another ;)
changing kernels r better do if ur running a ROM and not stock? I'm rooted and unlocked with stock 4.0.2. my better can last all day but thats barely using the internet or anything like that.
Hey thank you very much yes SolidOrange was the mod.:D
Kernels are dependent on the version of android you are running so most kernels are made for 4.0.3 now since most if not all current roms are based on 4.0.3
