[Verizon] Help my phone appears to have bricked itself
JustNexus
I took a bus last night and was using it the whole way. I am on aokp 25. 4.03.
Anyways I let it run down last night to off and now it won't boot and it won't boot into recovery. I can see the battery is charged icon but it won't boot.
What can I do?
I am trying to see if my computer will recognize it but its not looking like it.
What can I do?
As I mentioned on the other post....
Hopefully this works...
How to unbrick your phone.
http://androidforums.com/verizon-galaxy-nexus-all-things-root/474570-how-all-things-root-samsung-galaxy-nexus.html#post3957198
Otherwise, try 611 and request a replacement shipped.
the problem is android file transfer or my windows computer doesnt seem to recognize the phone but the phone is recognizing the charge from the computer but still won't boot. very odd.
Unplug it and pull the battery for a bit then replace and try to power on normally. If that doesn't work then try to power on in fastboot
Have you tried charging it from the wall (not the computer)? If not, try that for about 10 or 15 minutes then try to power on. If you get the battery icon when you press the power button, try again and long hold the power button.
Wow just got the phone on. Replacement phone coming Tuesday. The problem is the on button appears to be defective. Gotta relock this phone and install the stock rom when the replacement comes. But for now I am back on the grid!!!!
Every time the phone goes to sleep I have to pound on the on button to get it to work.
