hey, after trying to flash a custom rom on my galaxy s4 sch-i545 my phone has been stuck on the boot logo can get back to stock recovery not safestrap, and whenever i use odin it always says fail please help
Turn off your device.
Press and hold Volume Down + Power + Home buttons simultaneously. Release the buttons only when the Warning!! message appears.
Press Volume Up button to enter into Download mode.
- Connect your device to your PC. Odin should now recognize the device and the ID:COM field should turn yellow. This means that it has detected your device without a problem.
under pda select the odin flashable file in the link above ^ , and flash it.
that should be all you need to do to return to stock, working software.
good luck!
