[Verizon] HELP! Tried to install CM10.1 and folder structure is screwed
Status
Not open for further replies.
Vol4One
Member
I was on the last AOKP ROM before they put out 4.2. I installed CM10.1 nightlie and my folder structure got screwed. A '0' folder got added to SDCard folder and all my old stuff got put in there. I just wanna be able to restore my backup and it says MD5 Sum doesn't match.
Help please!
Just fyi. IF/When you want your thread closed. Hit the report button and type in the box that you want the thread closed. If not it may be a while before a mod or guide sees your post saying you want it closed.
OP problem solve, thread closed as per his request
Status
