Root [Verizon] HOW TO TETHER with root ??
Download a 3rd party tethering app like WiFi tether.
The sprint one needs a modified version of that app, the Verizon one might as well.
Personally, its easier to flash a custom ROM where it already is built in ;)
Well, personally I would try a custom rom flash as Rx suggested.
Nothing else is working for wifi tether?
Does everything else function normally on the device?
Ok. How do I achieve this?
C'mon guys! When you discover a fix for an issue, SHARE what it was that you did (best you can) so others with similar problems can have guidance as well. I know this is an older thread but hey, I'm doing what I'm supposed to be doing: SEARCHING! No answer here tho :-(
The only app I ever got to work on the s3 is WiFi tether router. Its a paid app, costs like 2 or 3 bucks but its worth it. It works flawlessly on sprint, boost, and virgin mobile. Not sure about the rest since I can't test.
