chadwick108 Well-Known Member Jun 14, 2014 #26 It's all good just here to help and you are correct about nc5 just think newer 4.4 required at least nc2
chadwick108 Well-Known Member Jun 14, 2014 #27 Baseband may work on mk2 but not certain... I know it will on nc2, cause that's where I am
chadwick108 Well-Known Member Jun 14, 2014 #28 I would try flashing nc2, or nc5 modems then the appropriate module depending whichever you use
chadwick108 Well-Known Member Jun 14, 2014 #29 Can be done via safestrap just make sure if you flash modems clear davlik cache and wipe cache I learned this the hard way
M maplewood Well-Known Member Jun 15, 2014 #30 A Solution! Flash gogolies-wififix-VZW-FN2-NC2-w-modules-SS.zip thanks to Cobra on: xda-developers
