halon
hakuna matata
Hyperdrive has been one of the more popular roms on the Galaxy S3. Hyperdrive is essentially a Touchwiz Rom with lots of customizations and tweaks! This Rom is fully stable. It will include the Stock Kernel with LOKI baked in. This Rom comes Prerooted and Debloated. With all of that extra bloat gone you should have more internal memory to play with. This Rom is full of customizations. Developer Sbreen94 has thought of pretty much everything. He still doesn't have this device.
Some features of the rom include All touchwiz functionality, full multiwindow with all apps enabled, Hyperdrive Control, Hyperdrive OTA so you will be notified when an update comes out (this rom series is updated often), Custom Hyperdrive 4 way reboot menu, MMS app extended settings, extended camera settings, extended browser settings, unplug does not turn on screen, no more full battery charge notification, removed gps icon from status bar, removed ongoing wifi in status, removed samsung OTA updates (this is big since samsung will patch root and bootloader), Galaxy Note 2 features like torch toggle, Enabled Verizon Wifi Tethering, and much more!
This is only the beginning for this Rom series updates and added features will steadily roll out. Grab this Rom at the source link below!
Source: Droid Forums and XDA
http://forum.xda-developers.com/showthread.php?p=41989203#post41989203
Rom Tweaks and Freatures
Full Galaxy S4 TW functionalities and apps
Full Multiwindow Enabled for all apps with Multiwindow Manager
Hyperdrive Control
HyperdriveOTA
Custom Rom Settings
Long Press Menu to Kill Current App
-Scheduled Messaging, Group messaging
-Screen on/off messaging toggle
-Message vibration and Signature options
-Save/Restore Messages
-SMS 1000 recipient limit enabled
-SMS limit per hour increased
-Enabled Split-View Mode On/Off Toggle
-Increased Max MMS and Image Size
-Disable SMS-MMS Auto Conversion
Custom Hyperdrive 4-Way Reboot Menu
Extended Camera Settings
-Use Camera with low battery
-Use Camera while on a call
-Zoom/Shutter with Volume Keys
-Additional Shooting Mode Tweaks
-Higher Video and audio bit rate in camcorder
Browser Extended Settings
-Exit and Terminate Options added
Unplug doesn't turn on screen
Removed Full Battery Charge Notification
Removed GPS icon from status bar
Removed Ongoing Wifi Notification
Removed Samsung OTA updates
No Increasing Ringtone in Phone
Galaxy Note 2 Features:
- Torch Widget
Unlocked Verizon Wifi Tethering
Enabled A lot of Additional Rom Languages
Sony Bravia Engine
360 degree rotation throughout
Removed ongoing notifications and annoying icons
Muted Boot and Shutdown Sounds
Fixes for OTG wakelock and Media Scanner drain
My Hacked Touchwiz Launcher for insane speed
Es File Explorer
Awesome Note HD
Removed all Verizon Branding and Bloatware from rom
Removed Trip advisor and Kies
Removed all Amazon Apps and widgets
Youtube with Screen off Playback and Tweaks
Hyperdrive Control
HyperdriveOTA
Custom Rom Settings
- Torch Widget
Sony Bravia Engine
Es File Explorer
Awesome Note HD
Hyperdrive Control
1.HyperdriveOTA -Download Rom Updates/ Themes and Apps and features!
Rom Updater
Google Applications
-Google Books
-Google Magazines
-Google Movies
Rom Mods
-Ad Blocking
-Hidden Language Enabler
-Volume Hack
General Applications
-Apollo Music
-CM File Manager
Verizon Applications
-Verizon Bloatware
-Amazon Bloatware
Samsung Applications
-Samsung Kies
Rom Updater
Google Applications
-Google Books
-Google Magazines
-Google Movies
Rom Mods
-Ad Blocking
-Volume Hack
-Apollo Music
-CM File Manager
-Verizon Bloatware
-Amazon Bloatware
-Samsung Kies
Custom Settings
General Mods:
Multiwindow Manager
Superuser Shortcut
Keyboard IME Notification Mod w/ toggle
Edge Browser Zoom Mod
User Interface Mods
Page Buddy Shortcut
LED Control
Icon Changer
App Mods:
CPU Information
Download All Files
Samsung Secret Codes
GPS Quick Fix
Media Battery Drain Fix
Advanced Mods:
Xposed Framework Installer
Per-App DPI Switcher
Custom Theme Engine
Multiwindow Manager
Superuser Shortcut
User Interface Mods
Page Buddy Shortcut
LED Control
Icon Changer
App Mods:
CPU Information
Download All Files
GPS Quick Fix
Advanced Mods:
Custom Theme Engine
Performance modifications
Full Optimized and Tweaked
Custom V6 Supercharger Binaries
Battery Callibrator Binaries
Improved EXT4 Performance
Full GPU UI rendering
My init.d scripts for insane performance
My custom Build.prop tweaks
Fully disabled Scrolling Cache
Cron
RAM Optimizations
Memory Optimizations
Network/Wifi Speed Enhancements
Sysctl Enhancements
Sqlite3 database Enhancements
Higher Video and playback rate
Better Image and Panorama Quality
Amazingly Smooth UI
Battery optimizations
Speed and performance that you haven't ever experienced on your GS4!
Cron
RAM Optimizations
Sysctl Enhancements
Amazingly Smooth UI
