Root [Verizon] Is my bootloader locked or not?
dweezle
I have a Verizon i535, S3, which has been rooted for a long time. TWRP 2.8.4.0 The problem is, that I remember that when I rooted it, I had the option to leave the bootloader locked or unlocked. I can't remember which I chose at the time. I presently have:
Android Version 4.1.2
Bootloader i535VRALE6
Baseband i535VRBMB1
PDA Version i535VRBMB1
CSC Version -I535VZWBMB1
Qualcomm secureboot: Enabled
I don't know if there are enough benefits to upgrading to a newer version of Android. 4.4 or higher. I don't want to lose my custom recovery or root. But, I guess I need to know if my bootloader is locked or not. Can anyone help with this?
Thanks
Just run root program doing it the same way as you did the first time. This time you can re-pick lock or unlock then you will know.
