[Verizon] Lightflow not working with Jelly Bean sourcery
My lightflow app stopped working once I upgraded to Jelly Bean. I'm currently on the latest sourcery rom. Does anybody know if the app is having issues with JB or did the rom cause this issue? Is there a fix out there? Any help would be appreciated.
Light Flow has been pretty spotty on JellyBean so far so it's more likely the app than the rom. I can't remember if JBSourcery had custom LED settings or not but you could check those out
Light flow works once you go into the app and select a notification and turn it off then back on and test it. Unusually do this once it twice if I reboot my phone. Once it starts working though it runs fine for me
