Tried the one click root method and my phone is stuck at the
"Downloading... Do not turn off target !! "
Been like this for 15 minutes now
Am I screwed ?
Thanks,
John
Rebooted, back stock and trying again.
I was a little worried about disconnecting with that screen showing
) and then check if it's rooted.at the end do you have to do the option 2 prep for recovery ?
ok cool
thanks and the root tool worked great after I figured out a few things
Thanks again,
John
yes it did
checked it with the root tool and SU is there also
