Root [Verizon] New Verizon OTA
Yes, you will lose root if you take the OTA.
To stop the update and notifications, use Titanium to freeze SDM.
Are you rooted and running a custom ROM and your phone is trying to update? Most custom ROM's take out the update...so if you are running a custom ROM your phone shouldn't be trying to update.
Well, if you ever want to run a custom ROM that will take care of that for you. The ones I like are Hyperdrive RSL8 (I had to stop using it because for some reason when I am on my VZW network extender at home it eats my battery up quick). I then moved to the Jasmine ROM and stayed on it for a long time and then upgrade to the Jasmine 2.4.4 version, but for some reason cannot get the hotspot to work. So, now I have moved on to biggins and love it. All 3 of these are great ROM's and very easy to flash.
