Frisco
=Luceat Lux Vestra=
I find this update actually slowed my phone down a tiny bit!
I have rebooted several times and cleared cache by holding volume and home button while the phone is off.
I find nothing new besides more multi window programs that I barely use ever, I give this update a negative.
Did you do a true cache partition wipe? Could be, it's just that I see you left out holding the power button along with the other two (you probably did but didn't type it in your post). Obviously if you went to the recovery menu area and used the volume down key to navigate to "wipe cache" then my question is moot.
Meanwhile, my phone seems at least as fast and responsive as it was prior to the OTA. I'm wondering if the slow down you're seeing was going to come along anyway as a result of something configured in the apps/widgets etc, and the update just happened to come to the device at that time: that happened to me with my Fascinate, so I first blamed the update then decided to check out my auto sync of Weather Bug (which I'd just installed before the OTA, hated it enough to get Palmary Weather Pro) and other widgets I then set to manually sync on demand, etc.
