shutterman
Never mind.
I was hoping that this feature was enabled while using a security pin for the lock screen.
Yes, I noticed that. I should have amended my post.I've seen a few posts on different forums with people saying they can't disable the VM app. I'm not sure how or why, but when I had this problem yesterday after updating, I was in my App tray, tapped and held on the VM icon, and dragged it up to "disable app" on the top of the screen, and it worked just fine for me. I'm running 4.4.2 stock Note 3, Verizon, with no modifications to OS or Launcher. So, I'm not sure why others can't do this?
I noticed a few of the apps were like this. The Disable Option was not available (nor is the Turn On after you disable them) except in the Launcher. If you even want to enable it again then all you have to do is show disabled apps and enable it from the App Launcher.
If I can get Verizon to give me the Basic Version for free, then I'll definitely enable the app and start using it. I only enabled Voice Mail on my account because that app said I could get VVM for free. No VVM, and I don't even want VM service on my line, because I loath having to call in to check it. Just IM me or call back later, instead, IMO.
For those using the free Basic Visual Voicemail.
Go into the Voice Mail application. Hit Menu, and Unsubscribe from the Trial. The app actually subscribed you to a Premium Trial and doesn't go to Basic Visual Voicemail until you end the trial.
If you don't do this, chances are high that your bill will go up by $2.99/mo.
After you end the Trial. Go Back into Voice Mail and Subscribe to Basic. Then after that it will be what you actually thought you were getting when you first set the app up
Just avoid hitting "Upgrade to Premium." The REPs had no clue what I was talking about when I called in about this.
It works now, though![]()
There is a much easier way.
Just go to the App Drawer. Press and hold the voice mail icon. You will see an option at the top of the screen to Uninstall. Drag and drop the icon to the Uninstall. It will ask you if you want to Uninstall updates, click yes, and the App will be gone.
Well, I happened to check my account last night and guess what? I was being charged $2.99! I called and they said that they didn't know what was going on but they would keep an eye on it because credits don't show up until after the bill is generated. Not sure why this is even an issue! However, I recommend that everyone check your bill just in case you are being charges when you thought you were getting the basic service for free.I'm guessing that now they know that something was wrong and that the basic service really is free. She set it up for me and now I have the basic service at no charge. Of course I'll keep my eyes on my bills
