Help Verizon Note 3 (N900v) cant connect to PC
kevin5fan
Hi so I got the Verizon Note 3 and I have a problem with the USB. I installed Samsung Kies on my computer but it says "The connected device is not supported by Kies 3" idk why cause it told me to download kies 3 if my phone was + Android 4.4. Anyways in Device Manager it detects the Note 3 as Samsung Android Phone also Samsung Android ADB Interface under it. Anyways all its doing is charging as I can't transfer files or anything since its not appearing in the Explorer. Im using the usb cable that it came with and also tried turning USB debugging on and off but nothing happens. Please help thank you!
