[Verizon] Optimizing Display colors
I have a rooted Galaxy Nexus running Lean Kernel (3.0.41) and Codename Android 3.6.0. I love this setup. I liked the features of a few other ROMs, but I find this setup gives me the best combination of battery life, features, and stability.
A friend mentioned that he saw a slight yellowish tinge to my screen, and of course, after he mentioned it, I couldn't HELP but see it. Since then, I've been tweaking with my advanced settings, and currently have it as...
Red at .51
Green at .49
Blue at .58
with the Gamma settings at
Red 2
Green 4
Blue 5
DSS Gamma Set at 8.
I looked around and see a few posts on various sites about suggested settings for people using the trinity kernel, but these recommendations don't translate to my phone. I like the settings as it is right now, but the white is not a real white (has a slight bluish hue, I think...).
So, I thought I'd write here to see if anybody had suggestions on their RGB settings, to see if I could learn from someone else... Any suggestions would be greatly appreciated...
After I used Trinity kernel I could not stand the now-apparent yellowish tinge that was provided by stock kernels. I use an app called TricksterMOD to help me play with the colors since there's a few presets in there already. Gives you a lot of options for the kernel too so you can check it out
+1 for Trickster Mod. Has a few presets that should get you in the neighborhood. Otherwise you'll just have to experiment. Every screen is different, some more different than others.
TricksterMod has a preset for morfic (trinity) colors. Once you set up your phone with them, you will never go back. They look awesome
