[Verizon] OTA upgrade to 4.2.2 cleared my root?
I just tried again using Galaxy Nexus Toolkit v10.1.0 and there is no 4.2.2 option or update?
How are we supposed to re-root?
I do believe the newest WugFresh toolkit is 1.6.3, so you'll need to update to that if you wish to go the toolkit route.
Is there another option I'm not seeing above in the root area?
I'm not all that great at trying to figure out what option to use when it comes to rooting.
Click Me!! =)
This post has all of the info you'll ever need when it comes to rooting, however, if it's too overwhelming (which I can understand), then just make sure you download the newest Wugs toolkit (1.6.3) and make sure you select the correct build number of your device.
None of these appear to be working and are items I have tried and have updated to.
Thank you for trying.
I don't know if you've tried or not, but if you set the Android build to "MYSID-TORO: Android *.*.* Any Build" in the updated Wug's Root Tool Kit it may work for you. Just follow the prompts. I got the OTA update to 4.2.2 this morning and lost my root as well, however the bootloader stayed unlocked. I just used this Root Toolkit method, and everything seems to be working fine. Good luck!
