DoctorEyeSight
Without installing the ROM/KERNEL/GAPPS, it showed 4.0.3.
Let me install everything and then see if it shows 4.0.4.
By the way, I'm using the ROM/Kernel that Steven58 posted above on this thread, seems like yours is the same?
Also, I'm going to use the GAPPS link that you provided to me on here.
Sorry, I'm still learning, but I really appreciate so much the help from you guys!
Okay, the radio flash and ROM are separate. That being said, if your radios are the 4.0.4 radios then this is what you should see:
Notice the info in "Baseband Version." If yours say this under "System Info" then you have the correct radio. But in order to be on Android 4.0.4, you must flash a 4.0.4 ROM. No way around it. Hope that makes sense.
jmar
