Root [Verizon] problems with random reboots
ilmar72
Hello
im running beanstown 4.3. I get random reboots no less than twice a day. I also have to pull my battery at least once a day because the whole phone locks up.
I read something about sd cards needing a fix if I was on a previous version of android. Could this be my problem? And if so... what should I do?
My rooted, rommed phone on Sophisticated 3.1 started doing that within the last couple weeks too. It was working OK before. I started using the Sophisticated Rom just after christmas when I had to update because my wife got me the Gear watch.
I tried the beanstown rom at first, but it had rebooting & crash problems from day one.
Sophisticated is one of the better ones. I'm still on 3.0 and get great battery life. I do get the occasional reboot, like maybe once a week.,
Ill have to try it. Ive been so busy that loading a new ROM seems like such a hassle... but I cant take this non sense anymore. This morning my phone was frozen. I had to do a battery pull. Then when I was pulling out of my driveway, the screen would not light... Had to do a second battery pull.
Random reboots happen very often.
Try upgrading to pac man nightly rom kitkat 4.4. I've had it for a while. Random reboot once every few months. I have nightly version. Note pac update in setup doesn't work. Use the normal method of updating via recovery.
I had this same issue a few months ago. I had been using the same SD for years thru different phones and carriers. Eventually it started to fail. Constant SD card unexpectedly, random re-boots and frozen phone all day. I replaced the SD card and haven't had an issue since. Good Luck:)
