streetfish
An updated version of this ROM was released yesterday. I flashed it last night - I was stock previously. I have heard very good things about the battery life on this ROM, either with included kernal or franco kernal (have not read how it plays with this ROM yet, works well with last version).
I have not noticed any bugs so far. I really like the configurable toggles (including 4G) at the top of the notification drawer, the additional options to unlock to from the lock screen (can customize up to 8!!) and everything added is ICS themed and integrates very well. Ability to add the search button back to the soft keys is cool as is clock speed and voltage mgmt also.
[ROM][AOSP][4.0.3] Codename Android 1.2.0 [Fully Open Source](01/24/12) - RootzWiki
CHANGELOG
### 1.2.0
* Common: default workspance now the same as google stock
* Common: new transistions and effects in the launcher for the app drawer and workspace (nebkat)
* Common: updated pulse notifications to use the colorpicker (now moved to interface settings)
* Common: added back the 4-target lockscreen and a new 4-target that unlocks to the right
* Common: new ics blue power widget icons (AndroidUser001100001)
* Common: added volume wake to lockscreen (Evervolv)
* Common: added setting for 180 degree rotation (cm/romanbb)
* Common: added back and updated the performance settings and added start-up settings and memory tweaks (cm/kejar)
* Common: set default wallpaper as chroma
* Common: lots of cleanup and reorganization
* Common: fixed sounds for all correct ics sounds
* Common: fixed issue with lightflow and the custom lockscreens
* Common: lots more that I forget but will update as the amnesia wears off O_O
* Nexus S: fixed battery percentage option
* Galaxy Nexus : auto backlight now on by default
* Galaxy Nexus : New Codename Android Kernel 1.0.2!! (Blueharford - our new kernel developer)
CHANGELOG
### 1.2.0
