VoidedSaint
Resident Ninja
http://rootzwiki.com/topic/22280-rom-eclipse-v14-42512/#entry601645
Battery Options
Features:
General
Full AOSP ICS 4.0.4
ICS bootanimation
Superuser and su binary built - ChansDD
Busybox
Mobile Hotspot Hack
USB Tethering enabled
4.0.4 Proprietaries added
Full ICS theme throughout the rom
Inverted Applications (Black/white text)
Status Bar Tweaks
1% mod - Accurate battery
Powerwidget toggles - CM source (customize in Eclipse Settings)
IME toggle - Romanbb
Battery options - Syaoran
Clock Options - Syaoran
Navigation Bar Tweaks
Added a persistent menu key option
Added Search key option with long press brings up voice search
Hide recents key and add long press home
Longpress back to kill - CM
Additional Apps
DSP Manager
Terminal Emulator
File Manager compiled with ICS SDK
Extra live wallpapers
Apex Launcher as the default launcher - Android Does
Eclipse Wallpapers app
Eclipse Settings integrated into the settings app (not much there yet)
Appwidget Picker - Boombuler/BlackDino for giving it the ICS appearance
Sense4 clock widget - just cause it looks nice
- J3bu5Cru57 [MOD] Sense 4.0 clock widget APK - xda-developers
Misc Tweaks
Extended power options (reboot menu) -CM
Volume to wake toggle
Longpress Volume to change music tracks - CM
Quiet Hours - CM
Custom carrier text
Screenshot
Navigation bar settings
Status bar settings
Facebook Sync - Roman
init.d support
sysctl tweaks
Changed DNS servers to Google
insecure boot.img
Extra camera effects are added
Downloads:
Download Eclipse v1.4: http://eclipserom.co...lick.php?id=110
md5: 60d9c5edada13400be7c556ab48e3883
Download Google Apps 04.25.2012: http://eclipserom.co...lick.php?id=111
Installation Instructions
1. Download Eclipse Rom
2. Download Google Apps (G-Apps)
3. Reboot into clockworkmod recovery
4. Wipe data in CWM recovery
5. Install EclipseRom-v1.x.zip
6. Install gapps-ics-20120425-Eclipse.zip
7. Reboot
Enjoy!!
Changelog:
v1.4 4/25/12
Fixed long press back issues
New Eclipse Settings
Added new wallpapers - ashclepdia
Added battery/clock options - syaoran12/romanbb
Set softkey animations to 0 to speed up Navigation bar
Removed bugmailer
Optimizing pngs during compile process (not sure if this even does anything)
Updated G-Apps
v1.3 4/20/12
Long press back kill app - Danesh
Volume rocker wake
Long press volume to change music tracks - CM
Revamped Eclipse settings interface
Added Quiet Hours - CM
Hide IME toggle - romanbb
v1.2 4/17/12
Dark UI for the keyboard
Long press home/hide recents - syaoran12
Custom carrier text (enter your own)
Increased softkey animation again
Cleaned up navigation bar padding and images
Organized Eclipse settings
v1.1 4/12/12
Added quad lockscreen
Added menu/search key options -xoomdev
Relocated carrier text to under clock on lockscreen
Shortened animation time to allow fast transitions
Enabled 360 degree rotation
Increased the speed of soft key animations
Cleaned up ICS theme for old framework
Sped up orientation speed
Fixed facebook sync
Added Eclipse bootanimation
1.0.1 4/8/12
Inverted MMS
Inverted Dialer
Inverted Contacts
T9 Dialer - CM
Updated Google Apps
Revamped toggles (changed code to point to images rather than a color)
Blacked out framework
Themed the GB portion of the framework to match ICS
v1.0 4/5/12
Initial Release
Battery Options
Features:
General
Full AOSP ICS 4.0.4
ICS bootanimation
Busybox
Mobile Hotspot Hack
Status Bar Tweaks
Additional Apps
DSP Manager
Terminal Emulator
- J3bu5Cru57 [MOD] Sense 4.0 clock widget APK - xda-developersMisc Tweaks
Quiet Hours - CM
Custom carrier text
Screenshot
Status bar settings
init.d support
sysctl tweaks
insecure boot.img
Downloads:
7. Reboot
Enjoy!!
Changelog:
v1.4 4/25/12
Removed bugmailer
Updated G-Apps
v1.3 4/20/12
Volume rocker wake
v1.2 4/17/12
v1.1 4/12/12
Fixed facebook sync
1.0.1 4/8/12
Inverted MMS
Inverted Dialer
Inverted Contacts
T9 Dialer - CM
Updated Google Apps
v1.0 4/5/12
Initial Release
