WOW - more new tweaks and customizations than you will likely ever need, or use!
★[ROM][MAR 2][4.3][MJE] Hyperdrive RLS7
I also thought it was time to donate to Sbreen94 again, since he's busy making our lives so much nicer. So I sent him some pizza money![]()
I may be having a couple of bugs related to the dirty flash. My wifi keeps turning back on by itself; but more importantly, I can't get the wireless charging notification to go out. I have turned it on and rebooted. I turned it off and rebooted. On. Reboot. Off. Reboot. And it STILL shows up!
Well, as fast as Kitkat is coming down the pipeline, I expect sBreen to release RLS8 in pretty short order. That will definitely be a clean flash.
if I use TiBu to make a backup of my HD6 slot, and then with safestrap delete the slot and make its again to clean install HD7. is if safe to restore the Tibu backup? probably safe for just apps. but contacts and memos and a number of other things ought to be ok right? Not really sure what changes under the hood with custom rom
Dirty flash didn't work for me either. Had little issues with notifications not working on all apps, a few other minor but annoying things. Did the factory reset and then restored apps only from TiBu and things seem to be working just fine. I don't keep many memos that get backed up but I don't see why it wouldn't be safe to restore those. I'm by far no expert but I would think the issues would lie in restoring data.
Yeah I got it figured it, I just flashed the stock firmware then rooted my phone again. Thanks. And yes, I'm on Verizon using the Note 3. I obviously need to update my profile information.@Jetguat: A dirty flash is simply a flash wherein you DON'T delete or wipe DATA. You can update the system software, but all your settings, apps and data are intact. Very convenient for minor ROM updates!
But if it's a major enough upgrade, that will result in conflicts... so I always recommend that people make backups and prepare for a full wipe if necessary.
@Bradyy: Welcome to Android Forums!
You ARE on Verizon, right? This is for Verizon Note 3s ONLY. If so, I can only suggest a reflash. Check the MD5s to make sure your download is good. Wipe data, cache, Dalvik and system, flash the ROM, and reboot. Good luck.
Glad you got it figured out, Bradyy!
Wow, this 128GB card is screaming. Copied everything over in about an hour... including all six Star Wars movies and the Back to the Future trilogy. Lots of room to play with!
Waiting for Hyperdrive 8 to hit and I'll clean flash it, no doubt it's being worked on feverishly...
Yes, I found it. Funny answering my own post. Forum kind of dead. Miss good old days.
