tdevaughn
Android Expert
JBSourcery Version 1.0 Public Beta---2
Please Read the release notes..This is Beta (while we believe Stable-and have done extensive testing) it is not complete and may have some issues as its released to masses.
So please let us know what you find, or what doesnt work.
JBSourcery tools is Bandwidth dependent. If your connection is poor then your results will vary. A good connection is required.
Team Sourcery IS Eagle1967, Devortex, Chizzele, tdevaughn, Alastrionia , atreyu381,JohnnyB15613
Xkape is on a personal hiatis and is greatly missed but we hope he will return soon.
And introducing our newest team member...............BigRalphN
We are on Github
Credits are given on Github and at
Please visit both to see all the great people involved in helping us make this great rom.
JBSourcery is the most Themeable ROM available.
JBSourcery Theme engine(No themes yet as this is beta..previews left up for those new to see what theme engine is all about)
Ability to change all framework and system ui images
Animations
Fonts
batteries
soft keys
Kernels
pull downs(Static Only--Google killed our ability for animated Pulldowns)
boot animations (and I believe the first ever boot animation changer that also changes audio(although we have not implemented audio on JB yet)
Website.
…Team Sourcery… | The Rom that updates itself!
and
Forums
Team Sourcery Forum • Index page
and Bug tracker... Please submit all feature requests and bugs here for better tracking.
Issues - teamsourcery - ICSourcery Bug Tracker - Google Project Hosting
PLEASE PUT REQUESTS AND BUGS HERE AS IT MAKES IT EASIER FOR US TO TRACK
Known issues-------
1)My Verizon Login- for my verizon , nfl mobile etc. states incompatible with this device.
I checked and our id is exact as 4.0.4 ota from verizon so not sure why this is.
FIX- goto mods and install verizon login fix.--all good after.
2)occasionally when rebooting system ui it wont come back just reboot phone. This has always happened but does seem to happen more on JB.
If you find any other bugs please submit them to-- or feature requests.
http://code.google.c...ery/issues/list
Fixed in beta 2---
cpu Frequency in tools now shows correctly
buld prop now shows-may error first time just choose it again
lcd density now goes down to 160 so you can goto that mode. i think they are calling it phablet
And a major feature added we think youll like.
The tools is still not rebooting systemui each time. it worked fine n ics problematic on jb we are working on it.
just rebooting phone when it doesnt come back works and is still faster than any other way to install our mods.
if we cant make this work on JB. we will have to revert it to a reboot rather than a system ui reboot so we are still working on it as its much nicer not to have a full reboot.
We have not tested or worked hard on tablet mode at this time.
Features--(besides already mentioned abundance of theming capabilities)
Battery -muiu battery bar,batterybar location,battery bar style(icon only,text only,icon with text,Batterymods(too many to choose),no battery)
clock adjustments-style(right,center,none),am/pm,days of week,color
Toggle options(aokp style)-auto rotate,bt,gps,wifi,airplanemode,vibrate,silent,torch,sync,
data,4g/LTE,wifi tether,usb tether
change order,brightness on toggle or not(location)
toggle style(icons,text)
toggle switches or line
Brightness control on status bar
enable advanced volume control,
navagation bar-small menu locations,menu visibility,
soft key color,glow color,
customizable softkeys with long press action and custom icons.
NavBar widgets
Navbar height(portrait),Width(landscape)
NavBar actions--home,back,recents,search,menus,toggle widgets,killapp,
Power,screenshot,hide softkeys,torch,custom-app.
Seperate notification and ring tone volumes
Camera shuuter sound on/off
Phone -T-9 dialing,
Dsp manager /music FX
In JBSourcery Tools--
change battery mods
change softkeys
Status Bar icons(changes any images in system ui
Misc Icons(mods to change icons in framework)
Glow Dots(change color/shapes)
Lock Screen handle(change to many different images)
Animations(change transition animations)
Boot animations(change boot animations-also with audio)Over 200 boot animations(audio not implemented yet)
Change fonts
Most popular kernels available to flash right from the ROM
change the pull down images
App manager(easily delete any app system or data, also recive much more info about apps)
Push notification(we will send you news,messages about the ROM right to the ROM-auto notification of new messages available)
Rom update(be notified of and install updates to the ROM right from the ROM no searching.
Miui root explorer with ROM
Theme manager(the first theme manage on any ICS ROM Full themes with previews)
Dev tools
Overclock settings controls
Spare parts
Terminal Emulator
Access to the secret testing menu
Wireless ADB
Block adds
Cache cleaner(app,sd,market history)
fix permissions
vm heap size
wipe battery stats
zipalighn
Build prop editor
Init.d controls(crons etc),
Kernel tweaks(fast charge,color mulitpliers,color gamma tunig, Voltage)
Extra apps-many other applications and updates wasily installed with the touch of a button.
Mods-made or ported by team sourcery available for easy installs.
Most of these items are updated live and additions, updates, changes are added frequently
Without user interaction each time you go to a section there may be new stuff.
And More!!!!!!!!!!
To set auto Push messages and Rom updates notifications goto those sections and choose menu at top right.
All tools stuff is now saved under sdcard/sourcerytools
Theme manger themes are no longer limited or seamlessly changeable. If you want to insure themes do not carry over
flash stock theme in between flashing themes.
After installing You will have an update to version 1.1 (this will put in wallpapers,camera effects, and some other things-highly recommended)
We are looking for developers and kernel developers who would like to join us in making this great rom.
Themers--Theme it up and send link to us at ICSourcery@gmail.com give us info and credits you want posted and well put it up in our theme manager.
We no longer have to build any part of a theme. and no longer limit what is themed.
This is a Public Beta of version 1.0 of JBSourcery by Team Sourcery.
While we believe it is stable It is far from feature complete, and had not been as throughly tested as we demand thus the Beta tag.
We wanted to get this out there as we know Jelly Bean is highly demanded..and for the first time we also feel this is a must update.
We are working on making this as complete as our previous roms and more but it takes time so we are throwing this out earlier than we normally would.
If you are reading and have a GSM Nexus..we will release the Beta and for the first time on the GSM Nexus very soon.
Most of these items are updated live and additions ,updates,changes are added frequently
Official Team Sourcery Downloads
You do not need to register to download but would be nice if you did so.
We will continue to support here also.
After installing look in mods at top and isntall 3.X addon for ics wallpapers, camera efects, version 2 sourcery notification and more.
We thank you for trying JBSourcery Version 1.0 Public Beta We hope you enjoy
Lets Rock
Donate to team Sourcery
Lets Rock
