Root [Verizon] Root Failed! VZW Note 3
ShanDroyd
fully stock, never before rooted device.
Using Kingo v. 1.2.1
failed to root every attempt.
USB debug is turned on.
tried using official Samsung USB 2.0 and 3.0 cables
any suggestions? :confused:
SM-900v
android v. 4.3
baseband v. N900VVRUBMJE
KERNAL V. 3.4.0
BUILD NUMBER JSS15J.N900VVRUBMJE
HARDWARE V. N900V.07
SM-900v
android v. 4.3
KERNAL V. 3.4.0
I used Vroot and it worked.
anyone know how to get rid of teh custom unlock screen at start up?
Shandroyd, I'm not sure if u ever got rooted, but if u didnt, u need to update to the latest version of kingo. Also, it may take a little bit for the app to recognize ur phone! It normally took my Verizon note 3 about 20 minutes to connect and then about 20 minutes to root.
Using Vroot is usually faster, can be a little more confusing with all the Chinese going on, but on 4.3 I found it easier.
On 4.4.2 now, you will need to use the Towelroot method :)
