[Verizon] Root using one step method
I had issues with CWM recovery flashed through rom manager and went back and pushed it through fastboot. It wouldn't properly install roms and kept boot looping but when I flashed through fastboot it has been fine.
If you have Root Explorer (or any root file explorer) installed, you will need to open and scroll down to /system. In here, see if you have "recovery_from_boot.p" there - if you do, you will need to change your Mount R/W to Mount R/O and rename this file to "recovery_from_boot.p.bak" - then open up ROM manager, reflash clockwork and then you should be able to reboot into recovery with no issues.
+1 on the above. Go to Wugs page where the one click is located. His first two posts explain everything. I got it all first try. He mentions to flash from rom manager and use a root explorer app, I used ES file explorer, to rename a file. In ES file explorer, go to settings, enable root explorer at the very bottom and click below that to change from read only to read/write so you can rename the file
