Root [Verizon] Rooted, using Titanium backup which files to Backup?
zzpree
Hi! I have successfully rooted my phone and want to protect it the best way possible.
The problem is I am not sure which files to BU. Any thoughts? At this point, I am not flashing a custom ROM {NOT EXPERIENCED ENOUGH}. Also should I freeze or completely remove bloatware? Pros and cons. :what:
Thanks in advance
~ Cheers
Sent from my Nexus 7 using Tapatalk 2
Thanks in advance
~ Cheers
backup anything you would want to be able to restore after a factory reset...i recommend freezing over removal...sometimes freezing or removing something can break something else...if you freeze it, you can just unfreeze it...if you've deleted it and not backed it up...then you need to track down the apk...
Thank you! I froze some apps now running in safe mode and many of my apps including Titanium-bu aren't there.
Sheesh, not sure now what to do.
Thanks in advance
~ Cheers
Here is one of many YouTube vids on the app. It helps me to see a video rather than reading how-to! Hope it helps!
