Root [Verizon] Serial number
Hey, I moved this to the regular forum, as it is not a root-related issue. Thanks for understanding. :)
I apologize fbm, have been told you were correct in your placement... moving back now.
Sorry this is a root issue, he likely used the original root ROM.
Solution: Flash Root66 or one of the Verizon based root ROM, the factory reset the device. Problem solved.
Okay cool and thanks guys. Figured it was root issue but didn't know for sure since I didn't check initially.
Thanks flashed the root 66 and serial number gone. I did not wipe and I don't appear to be having any issues.
Anyone explain the different Odin modes and why? Pda, boot, phone etc
I believe boot will reboot your device, and you definitely don't want to use the Phone mode to flash your device, use only PDA mode or end up with a nice paperweight.
When you say gone you mean no field for it? Which should be normal for a Verizon phone.
As for Odin, sorry just be guesses. I am new to the tool.
