kinghen
I know not the best choice but for 199.00 and 20 a month I thought I would try it out. I have tried to get a google number but voice can't verify the tab number. Do I need to root first? Also trying to connect via blue tooth with my droid2 says it is paired and the tab says it is paired but they wont connect? Just as info my moto stereo head set which is blue tooth connects go figure.
Any help would be appreciated!
Thanks Henry
Thanks Henry
