Is it possible to tether without Verizon knowing we are doing it? If so how?
VZW knows..... if you abuse it, they'll care
What about Foxfi? Works great on my Galaxy S1.
There is no cap. There are people who use 20+GB (not me). However, I bet there is a data usage level that flags your account for further scrutiny.?? I wasn't aware of a 5 GB cap. I guess an unlimited data plan is only unlimited to a point?
How to Tether Galaxy S3 As A WiFi Hotspot | Root Galaxy S3
tells you how to if you need to, at the moment looks like you can share your data plan via tethering as a modem/usb but nothing is available to enable the wifi hotspot without rooting your device and this link covers that too.
FoxFi works just fine without rooting.
My comment was that FoxFi in general works on most android phones without root.
From foxfi's website:
"*Support for the new Galaxy S3 and the new ICS update for Epic Touch are being worked on. Should be compatible soon in a future update"
So I guess the short answer is at this very moment, no, but it shouldn't be long before it does.
Actually, it's working 100 percent perfectly on my Verizon S3. Used it for half an hour or so yesterday...
Grossie - when did you get your VZW S3? I've never rooted a phone, so can you direct me to the a good beginner's guide? I don't want to screw something up!
Have my S3 from VZW but FoxFi doesn't work. Neither does a hard tether via PdaNet. And there's no Android tether option that I can find. Is root my only option?
