[Verizon] Touchwiz ROM for GNEX?
Not sure if a TW ROM has been ported to the GNex. I'll look around and circle back later.
You actually don't need a ROM for that. Here is the launcher apk from the S3 back when it was released. You just install it like any other app.
I don't just want the launcher, I want integration. I want my signal meter and notification bar to change and everything. Even my lock screen. I'm thinking about getting an S4, and I wanna get used to the touchwiz experience, as its changed a lot since my Stratosphere. Thank you for the apk though, I'll take a look at it.
Edit: Installed and attempted to launch. It fails every time. No matter what.
Hmmm... I installed it when I first downloaded it quite some time ago and it worked. I was on 4.1 then... possibly not compatible with 4.2 if you're on that.
I'm on 4.2.2, so it probably won't work. I wish I could get a ROM based on the Galaxy S2's version of touchwiz, I really like the look of it.
Yeah, I don't think your going to have much luck. Most people got the GN to get away from manufacturer skins so there's not a lot of interest in porting it to the GN.
Also, because it TW isn't native on the GN it'd be a buttload of work and would still have missing features and such.
