Root [Verizon] Towelroot Method (4.4.2)
I have done something wrong I know, but I have done this before on other phones with no problems like this. Each is different I know. Thanks for your opinion and I will keep working on it.
Can you get into the system did you make a backup this problem sounds like your not ROOTED .or didn't finish root process . and maybe such as was mentioned in the thread earlier where you need to upgrade your kernel . many things to do before root
I understand I'm not much help at this point. Frustrating when I followed the steps and the SS fails to open. I appreciate your helping me as much as you could. I will figure it out at some point.
Did you root with towel root first
Yes, I did root with towel root.
EDIT:
Downloaded a root checker and saw where busybox was not installed. I installed it and reran the safestrap app and it worked. Crazy, huh...
Now, did I read earlier that roms needed to be in the Stock slot or can I install in slot 1?
You can try the stock slot. But I know KitKat cyanogenmod works in slot1. But let's work on getting the phone to get into the system
I have it working like it should now. I can get into safestrap upon boot like it should. Just needed to install busybox for it to install properly.
Now I want to go ROM crazy...LOL
Everything seems to be working like it should now, just have not flashed a Rom.
Thanks for your questions, they actually pointed me in the right direction.
I have some files you will need to keep in a safe place or just come back to this thread.
This is the full stock file and instructions on how to get device back to stock just in case you have a failure.
http://www.sammobile.com/firmwares/3/?download=29319
That URL has the firmware and Odin files to correct problems . it will correct by putting you back to 100% stock unrooted all that .
Now this other URL is tricky it has everything you need such as n2kernel the towel root and also explain the STOCK SLOT on the recovery . now this URL
http://forum.xda-developers.com/showthread.php?t=2787627
Also has the stock rooted firmware and etc so if you wiped your slot stuck cause you didn't use the recovery the correct way :eek::D o its funny I did I somehow erased my whole SD card and internal device . so be careful . if you do here is the path to start and get you on your way
What does "nightly" and "snapshot" mean? Are they updates to the rom? Seem smaller in size than usual.
Cyanogenmod nightlies are just builds that the dev fixes and makes updates to NIGHTLY . NOW snapshot and the M8 M9 are monthly builds.
http://www.phonearena.com/news/Cyan...Xperia-Z2-Xperia-Z2-Tablet-HTC-One-M8_id58936
Also take a look at
http://forum.cyanogenmod.org/topic/75374-snapshot-vs-nightly/
And now WHAT IS CYANOGENMOD.
http://wiki.cyanogenmod.org/w/About
I have at&t sgh i317 note 2 on 4.4.2 last updated march so its before june and I cant seem to ROOT fir anything in the world ive tried odin an all those framaroot an now I have towelroot an it wont work still I found how to change the band by tapping towelroot 3 times an it lets me change it for my phone but it still wont root my phone I NEED HELP ASAP PLEASE
Hello and welcome to the forums . sorry but can I get this straight towel root was told to you it works on note 2 devices . can you point me in that direction of the thread . . CF ROOT was the only one TOWEL ROOT doesn't work on note 2 .
